source autoblog
Chevy recalls 2005-2007 Corvettes over possible roof panel separation by Jonny Lieberman (RSS feed) on Dec 29th, 2009 at 9:28AM
Do you own a Chevrolet Corvette? If so, is it a 2005 to 2007 model? If you answered "yes," does your 'Vette have a removable top? If (again) yes, have you noticed a snapping noise while over speed bumps? What about extra wind noise? Does your roof panel move when you slam the door or rear hatch? Have you noticed water beading down on your head during wet weather even though the removable roof is in place? If you answered "yes" to three or more of these questions, Chevrolet has a recall for you.
Seems as if the glue that holds the outer portion of the panel to the Corvette's roof frame has been failing. Full, worst case scenario consequence would be the outer part of the panel separating completely and flying away where it "could strike a following vehicle and cause injury and/or property damage." Seems as if we've heard something about this adhesive problem before... way back in April of 2006.
According to General Motors and the National Highway Traffic Safety Adminstration, all 22,090 2005-2007 removable roof Corvette owners would be well advised to go down to their local dealer and get a new roof, gratis. Also: special bonus props to whomever can name the special edition Corvette pictured above. There are a couple of clues if you look hard enough.
[Source: National Highway Traffic Safety Administration]
rappel pour les corvette C6 de 2005 à 2007 !
Re: rappel pour les corvette C6 de 2005 à 2007 !
Complément d'information en français:
GM rappelle 20.000 Corvette General Motors rappelle un peu plus de 20.000 Corvette pour un problème au niveau du toit amovible. Aux Etats-Unis, les propriétaires de Corvette C6 Coupé (2005-2007) et Z06 (2005-2006) sont invités à entrer en contact avec les concessions General Motors. Le géant américain rappelle en effet 20.090 unités de ces modèles pour un problème au niveau du toit.
Selon la National Highway Traffic Safety Administration, le joint entre le toit (amovible) et la carrosserie aurait "du jeu", ce qui engendrerait des nuisances sonores. Dans le pire des cas, le toit pourrait même se détacher du véhicule…
General Motors indique que les rappels interviendront dès janvier pour un remplacement (gratuit) de la pièce.
cadillac france ne suit plus les corvette, peut être changement d'attitude en janvier m'a t'on dit !
sinon, pour 2 garages parisiens, ils sont en congé jusqu'à lundi, donc patience !!
Salut je rentre de chez Jean Charles automobiles , Paris 16, pour une révision.
Tout va bien mais on m'indique de changer le toit (j'avais remarqué...) mais la prise en garantie n'est pas sur... Il me rappelle...
Soit disant que la situation de GM en France a changé, à l'époque j'avais une c5 en 2005-2006 les rappels avaient été pris en garantie, par Delta Italie.
Avez vous deja changé votre toit en France pour C6, cela etait il gratuit ?
demande faite par Jean charles auto, refusé, m'ont appelé ce matin
c'est un peu naz non ?!
